Author Topic: 1/32 scale milk tanker with modified Century cab.  (Read 6720 times)
Ray F
Re: 1/32 scale milk tanker with modified Century cab.
« Reply #15 on: September 13, 2016, 05:52:38 AM »
I Agree with Charlie, Very Sharp Indeed !!!  :o 8)
« Reply #16 on: September 13, 2016, 09:19:15 PM »
Fantastic job here JP, I really like the way you wrapped the tank, great idea with incredible results! The cab re-work look great too, nice combo, well done.
What did you use to create the seams in the tank sections?
jpgraphiks
  • That's Headly Lamar.....
« Reply #17 on: September 15, 2016, 05:59:09 PM »
Hey, Jim
I used another piece of aluminum flashing like a flexible ruler taped around the tank then carefully scribed the lines in (I actually used a scribe tool, but you could use the back side of a utility knife blade. I experimented on a scrap piece first!....). it took about 6 passes for each "seam" to be visible/realistic enough. As long as you put only moderate pressure, even light pressure on the first two passes, the lines have less tendency to go off course.  each section is 8 scale feet.
JP
« Reply #18 on: September 23, 2016, 12:03:15 AM »
Hey, Jim
JP
Thanks, it worked well! I used that technique on the stainless fender on 1/87 scale tankers I did, takes a fair bit of pressure to scribe them in, when it works, looks great tho!
rick315-8
« Reply #19 on: September 30, 2016, 05:54:57 PM »
Great looking combo Jim,....you did a heck of a good  job on both truck and tanker.....your outdoor photography and diorama came out really good !
......"Automatics?....we don't need no stinking Automatics !"
jpgraphiks
« Reply #20 on: October 04, 2016, 05:47:32 AM »
thanks, guys!
Jim, Ill have to check out that tanker you did in 1/87.....
JP
« Reply #21 on: October 04, 2016, 11:38:08 PM »
thanks, guys!
JP
Thanks JP. here is a link to that build, the fenders are the subject.
http://hankstruckforum.com/htforum/index.php?topic=69290.0
TableTopTrucker
  • This is a Test
« Reply #22 on: December 09, 2016, 12:05:43 AM »
Awesome Job...
Have missed being in here..
Hopefully some time will be spent on some stuff..
Robert
TableTopTrucker
Doing Television one Venue at a Time.
Douglass-2011
« Reply #23 on: December 09, 2016, 10:21:44 AM »
Looks like it`s missing side marker lights on the trailer and steps on the fuel tanks. Other than that, a super build. I wish I could build that good. I never would have thought to do what you did to build that trailer. That pipe was genius.  8)
Bermuda Ken
    • C&G Site
« Reply #24 on: March 07, 2017, 09:58:16 PM »
very nice...if you wanted a "round tube" trailer, I suggest using stainless steel piping.  Here in WI this can be picked up cheaply at farm sales when the milking equipment is sold.
INTERNATIONAL TRUCKS....anything else is just a car!!!
Looking for IH 4300 EAGLE BROUGHAM items.  Collector of IH & KW truck literature.
